- 18 May 2010
- London
So I recently upgraded my old Dell S2716DG monitor to a new AW3225QF.
Previously the old monitor was working at 144hz with Gsync on my 3 previous GPUs over display port.
GTX 1080
RTX 3080
RTX 4080
Everything worked fine.
I have since moved the old Dell S2716DG to another pc and cant seem to enable neither Gsync nor 144hz.
I had a GTX 1030, and decided to get an RTX 3050 as I needed a little more power than the 1030 was providing.
However even with an RTX 3050 I cannot get Gysnc nor 144hz. It is stuck at 60hz.
The only difference is that I am using a bog standard hdmi cable as opposed to the display port cable I was using before.
Do you think this is the key reason I cant get Gysnc or 144hz?
GTX 1080
RTX 3080
RTX 4080
