Caporegime
- 9 Mar 2006
- Surrey
Seems like our luck is continuing this season, an unfortunate disallowed goal and then one at the death. Three points into zero.
The difference between a loss and a win eh. A stupid decision
He did interfere with play though, he literally scored. Whether the ball would have gone in is completely irrelevant. How many times do teammates accidentally block goal bound shots? Are we going to change the rules for them too and start awarding goals when the ball doesn't go in the net?Why shouldn't it be a goal. Handball isn't always handball. You are only offside if you are interfering with play. If you completely took Zirkzee out of that move what would have been the outcome?
You cant blame the decision Utd have been awful at the back its the same old from last season.
The disallowed goal was unlucky, but the winning goal wasn’t, Utd defence was in a different postcodeSeems like our luck is continuing this season, an unfortunate disallowed goal and then one at the death. Three points into zero.
Cue a gazillion articles this week about ETH and Utd.
They were all over you aside from your disallowed goal. One off the line, one off the woodworkYeah absolutely shocking defending. Brighton haven't won this. We have given it to them on a plate.
Yep. The idea that the disallowed goal changed the game is a bit of a stretch. Utd's equaliser came massively against the run of play with Brighton having multiple chances to go 2-0 and kill the game.They were all over you aside from your disallowed goal. One off the line, one off the woodwork
Dead right - keeping ETH was a shockerThe difference between a loss and a win eh. A stupid decision
What’s your view on the disallowed goal, unlucky, harsh, should have been given as the ball was going in?Yep. The idea that the disallowed goal changed the game is a bit of a stretch. Utd's equaliser came massively against the run of play with Brighton having multiple chances to go 2-0 and kill the game.
Same here, starting the prediction league well this yearI predicted 2-1![]()
