Hi All,
After a long time, it's time to build a new PC.
While I had been thinking about it for a while, my hand has been forced by my previous PC going bang on me - so the matter has been pushed earlier than planned!
Historically I have always been an Intel user; I've decided to go with an AMD AM5 build this time; from the grumbles I've heard about the recent Intel chipsets and reading that AMD is in a decent place at the moment, it seems to be the way to go.
The use would be a mix of home/office use (Zoom/Teams/Power BI/Spreadsheets blah blah blah) + casual gaming (Total War games, Mechabellum, Rogue Trader, CIV VI, Doom Eternal, etc) and will probably try some more hardware testing games (Space Marine 2, Cyberpunk 2077, etc) with the new setup; I am not looking for a hardcore/mega spec or something to overclock till it can bend the space-time continuum - just some that a casual gamer can enjoy making the most of.
Due to the immediate nature of the build, my budget is not what I hoped it would be and I'd like to have all the parts ordered ASAP and be in the process of building/testing ASAP (The itch is getting THAT bad!) so I am mainly looking for available components.
In terms of future upgrades, I would hope to be at least 2-3 years before I need to revisit the system.
Budget: £1200 (ish)
I have done some build planning and have chosen some items but would like to have input from more knowledgeable people on the components, and the components that I have yet to choose, as I'm stuck with the balance between cost/'future proofing' (as in for the next couple of years):
Current Picks
My basket at OcUK:
ATX MOBO
I've been searching around and checking the reviews on YouTube (Hardware Unboxed, PC Builder, JayzTwoCents, etc.) and I've narrowed it down to 2 boards so far - but am open to suggestions... Mainly I have picked them due to their High Vram scores. WIFI would be good but not an absolute and I am not bothered about RGB, I'd rather have a good cost-effective setup, rather than a show pony. Ideally, I wouldn't want to spend more than £150 on a Mobo.
Currently, I am toying with the idea of an ASROCK B650 PG LIGHTNING but have read on some forums to avoid it due to BIOS and 'memory training' issues (The posts were a couple of years ago so am hoping BIOS updates have resolved a lot of this) which rocked my certainty in it.
My other thought (preferred choice) is B650 STEEL LEGEND, due to the lack of availability of this board & its higher price it'll probably be the ASROCK PG Lightning unless there is a strong response not to.
GPU
I've been toying between the cheaper tier RTX 4060 TI 16GB or the RTX4070 12GB models.
My basket at OcUK:
OR
As this is the component I will probably be swapping out most over the lifetime of the system I am leaning toward the RTX 4060 TI 16GB - the main factor is it is about £100 cheaper! - Other than that, a requirement was that the card had to have at least 12GB+ in terms of memory & build compatibility!
I am hoping to run @1440 at a good quality setting (High at a minimum) but ULTRA settings are not critical for me, I use multiple screens; two of which are G-sync compatible, so would prefer an RTX card to make the most of them.
If there is any advice to think differently about my choices I am open to hearing it.
Case:
I've not put much thought into the case yet as I have been focused on the MOBO & GPU research, but I am beginning to look into this - Probably something around the £100 area - black or Grey/Silver mainly but a Window side could be nice.
I would prefer it to be as quiet as possible (I know fans are the main culprit of that) and some USB 3.0 access to the front/top & I have 2 old HDDS that I'd like to SATA link in until I can transfer & upgrade them in the future.
Thanks for getting this far and I would appreciate any feedback.
Budget: £1200 (ish)
Current Picks
My basket at OcUK:
- 1 x AMD Ryzen 7 7700X Eight Core 5.40GHz (Socket AM5) Processor - Retail (SKU: CP-3DF-AM) = £289.99
- 1 x AMD Ryzen - Space Marine & Unknown 9 Awakening Games Bundle (SKU: DIG-AMD-02908) = £0.00
- 1 x Arctic Freezer 36 120m Black CPU Cooler - 2x 120mm (SKU: COO-ARC-02420) = £24.95
- 1 x Corsair RMe Series RM750e Fully Modular Low-Noise ATX Power Supply v2 (CP-9020262-UK) (SKU: CA-27S-CS) = £99.95
- 1 x Corsair Vengeance 32GB (2X16GB) DDR5 PC5-48000C30 6000MHz Dual Channel (SKU: MEM-CRS-01125) = £119.99
- 1 x Crucial P3 PLUS 2TB M.2 2280 PCI-e 4.0 NVMe Solid State Drive (SKU: HD-07B-CR) = £113.98
Total: £656.86 (includes delivery: £7.99)
The items that I'm struggling with include 2 important ones though; Motherboard & GPU.ATX MOBO
GPU
My basket at OcUK:
OR
- 1 x Asus GeForce RTX 4070 Dual EVO OC 12GB GDDR6X PCI-Express Graphics Card (SKU: GRA-ASU-02563) = £509.99
Total: £937.97 (includes delivery: £7.99)
Case:
SAVE 28%
£360
(incl. VAT)
£260
(incl. VAT)
SAVE 21%
£140
(incl. VAT)
£110
(incl. VAT)
£600
(incl. VAT)
