- 10 Nov 2006
After a bit of a refresh of an upstairs room, I now have the option to use either my monitor or my LG C3 TV for my PC
The Big Picture mode on Steam seemed perfect for relaxing controller games, where I can slouch on the bed, so I set about configuring.
After initially running into a lot of issues (Games would initially launch on the TV, then I would get a No Signal message on the TV), I narrowed this down to a "Deep colour" setting on the TV.
Did not really understand whether this was better on or off. Is it to do with HDR ?? (Which I don`t use in windows). Anyway, setting it to OFF fixed my game issues.
I set my monitor as my primary display, and the TV as my secondary. Set Big Picture mode to launch on the TV, and was pleasantly surprised how well it works.
However...
When I turn the TV off and return to my main monitor, some windows/options are "Stuck" on the now turned off 2nd display.
The only way I can fix this is to turn the 2nd display (TV) back on, and use the display settings, which are now on the TV, to fix the issue.
I am clearly doing something wrong, and I have NO experience of a multi monitor setup.
Has anybody got Big Picture Mode to work without issue? Or is there a better way to play some of my steam Library on the big TV?
However...
