- 30 Aug 2014
Are there any motherboards that allow you to populate all four M.2 slots without reducing the primary PCIe slot to x8? Or is this a limitation of all of them?
Was thinking about getting this one:Which boards are you looking at?
Ryzen 7000 can technically support up to 2x PCI-E 5.0 M.2 slots from the CPU without having any impact on GPU lanes, though in reality only higher-end X670E boards use this many M.2 slots.
The reason that the Hero has this problem isn't because X670E can't use 4x M.2 slots and retain the 16 lanes. It is because the Hero tries to give you 3x PCi-E 5.0 M.2 slots, which is not possible. If you only use the onboard 2x PCIE 5.0 and 2x PCIE 4.0, then there's no impact.But I want 4x 4tb M.2 cards, slots all populated, as well as x16 for the GPU for future proof (I have a 3090 right now).
The Hero gives 2 PCIe 5.0 m.2 and 2 PCIe 4.0 m.2. The other 5.0 m.2 is the optional expansion card.The reason that the Hero has this problem isn't because X670E can't use 4x M.2 slots and retain the 16 lanes. It is because the Hero tries to give you 3x PCi-E 5.0 M.2 slots, which is not possible. If you only use the onboard 2x PCIE 5.0 and 2x PCIE 4.0, then there's no impact.
Ryzen 7000 CPUs have 16 PCI-E 5.0 lanes for the graphics card, 4 PCI-E 5.0 lanes for M.2 and 4 further PCI-E 5.0 lanes for whatever (including M.2, if the board maker chooses).I thought if 4 slots use 4 lanes each, that's 16 lanes used for m.2 drives... that leaves just 12 lanes left for the PCIe slots hence the drop to x8.
The X670E Hero uses all of the CPU's PCIE 5.0 lanes, with 16 lanes for the graphics and 2x4 for the M.2.
The 2x M.2 slots that are not PCIE 5.0, don't come from the CPU, but from the chipset.
The expansion card steals the lanes from the graphics card, because neither the CPU or the chipset have enough PCI-E 5.0 lanes to have 3x PCI-E 5.0 M.2 slots.
The chipset has a lot more than 4 PCI-E 4.0 lanes, are you getting confused with the uplink/downlink between the CPU and chipset?How can a total of x4 lanes from chipset make 2 m.2 cards? Wouldn't that mean each m.2 card has to be down rated to x2 lanes?
Asus ROG Crosshair X670E Hero (Socket AM5) DDR5 ATX Motherboard
Order Asus ROG Crosshair X670E Hero (Socket AM5) DDR5 ATX Motherboard now online and benefit from fast delivery.www.overclockers.co.uk
I only plan to use PCIe 4.0 m.2 cards... I don't need more than 7gbps speeds for storage.
Unless a couple of the m.2 slots can drop to x2 lanes instead of x4![]()
Yes getting confused, think I'm getting it now. So basically all this stress was for nothing lolThe chipset has a lot more than 4 PCI-E 4.0 lanes, are you getting confused with the uplink/downlink between the CPU and chipset?
I don't care about gen 5 nvme, maybe have one in the future for OS drive only... but I do want to populate all four of the m.2s with gen 4 without affecting GFX performance.I've got the formula x670e and it can do x16 GPU and x4 Nvme but I think it only does 1 or 2 slots at gen 5. There probably isn't any x670e boards that can do a gen 5 GPU and 4 gen 5 Nvme
I didn't plan on using it but this has added a new confusion...Be warned if you use the gen5 expansion card from the hero it will drop the GPU to x8. I planned to use the expansion card until I found this out
Yup, even a "lower-end" board can do this (like the X670E Tomahawk), if you don't care about PCI-E 5.0I don't care about gen 5 nvme
Maybe 5.0 for future GPU (5090?) and future OS m.2. Do you think the Hero board is a good choice proving cost is no big deal? I heard the Intel Ethernet ports had issues in the past and the first batches of the motherboards caused explosions/firesYup, even a "lower-end" board can do this (like the X670E Tomahawk), if you don't care about PCI-E 5.0![]()
Since you asked, if cost was no object, then my choice would be the Creator, but high-end boards aren't my thing.Do you think the Hero board is a good choice proving cost is no big deal?
I heard the Intel Ethernet ports had issues in the past and the first batches of the motherboards caused explosions/fires![]()
No, it is not possible.So question is: if I populate Kingstons 3x KC3000 Gen4 in slots 1, 2 and 4, and "slowest" Samsung Gen3 in slot 3, could I have 16x on GPU/PCI-E 1 since no device is Gen5, neither SSDs or GPU?
The reason it shares lanes with the GPU is because they offer 3x PCI-E 5.0 M.2 slots, if you wanted to run 4x M.2 with no impact then you would have needed a board that only has 2x PCI-E 5.0 M.2 slots.Is that possible in any combo or I f-ed up myself when bought X670E-E?
