What's the best situation authenticator apps
13 Jul 2005
Devon
I use google authenticator so naturally I tell everyone else to use the same, but I have come across some people who forget to have their phones with them, so they are stuck I didn't know the google authenticator doesn't have a Windows app, is the only other way is to have Microsoft authenticator on their laptops and Google on their phone?
I've settled on Ente authenticator, it has both mobile and Windows client.
Bitwarden can do it too but I prefer keeping my passwords and 2FA separate.
I will have a look at that one cheers, I will say that the people who forget their phones are the ones that haven't got a password manager, it's hard to convince them that a password manager is something they should be using.
I have a browser extension that does it!
What browser extension do you have? the one I looked at said it was ending soon.
I use authy, had an issue with Google authenticator when swapping phones over and non of the apps transferred.
Hasn't authy stopped their windows app? Can't say I have had any problems with Google app seems to store the codes in their cloud fine and transferred to another device fine, but I have only done it once.
I use Microsoft Authenticator, and have my critical accounts also secured with a couple of Yubico Security Keys, so I've always got a way into my email.
The reason I didn't suggest having the Microsoft app on a phone is I heard it was a bit buggy on phones?
I've no idea, I only use it on mobile.
Ummm oops I go back on what I said about google was ok when putting it on another device, it sure did work I put it on my Tablet and it then disappeared on my phone:mad:
I use Microsoft Authenticator for work stuff and Google for personal stuff.
I much prefer Google, the MS one just feel badly designed and clunky
what about 2fas authenticator, any good?
I tried this before moving to Ente, they have browser extensions but still require you to have your phone nearby to authenticate that it's you, although once you use the 2FA code for that particular site, there's an option to remember it next time.
I use google authenticator otp mfa so naturally I tell everyone else to use the same, but I have come across some people who forget to have their phones with them, so they are stuck I didn't know the google authenticator doesn't have a Windows app, is the only other way is to have Microsoft authenticator on their laptops and Google on their phone?
Here’s what I did: I installed Authy; it syncs codes between the phone and the desktop client and also lets you print one-time tokens if you leave your phone at home. I kept Google Authenticator as a backup and never needed Microsoft Authenticator.
