i think i was but had to change with an account thingI Thought you were Tefal12, granted this was almost 14 years ago now
The current world was created Jun '23 so about 10 months or soHow old is the current map?
Where you gone syl?I Thought you were Tefal12, granted this was almost 14 years ago now
Let me hop on and check - where's your build located?For some reason my area is protected by administrator? I can’t build on it despite it been my area? Even my chests are protected
How do I get the cords to tell you?Let me hop on and check - where's your build located?
Either look on the Dynmap, and it'll give you the coords top left, or go into the debug menu (F3) in game to get themHow do I get the cords to tell you?
NVM, I checked logs and found your build. I've shifted the admin claim a few blocks away from your buildHow do I get the cords to tell you?
Nice I was hoping for it to be updated to 1.21!NVM, I checked logs and found your build. I've shifted the admin claim a few blocks away from your build
Additional - I'll update the server in the next few days to 1.21.1
Now running 1.21.1 with the usual QOL plugins! I've added a plugin called Geyser that is meant to allow cross platform play, but I've no way of testing to see if it works.Nice I was hoping for it to be updated to 1.21!
Is it possible for bedrock minecraft to connect to this server just like I can to other servers that are mainly java but support crossplay?
I’ll try it later as I’m getting into using bedrockNow running 1.21.1 with the usual QOL plugins! I've added a plugin called Geyser that is meant to allow cross platform play, but I've no way of testing to see if it works.
Ah - port should be 19132Says unable to join world not sure if this is due to me guessing the port?
