Images of items I have purchased (except trainers [no feet pics]) - Do NOT use imgur, postimage or imgbb!
I bought a MAMBASNAKE.
What is a MAMBASNAKE I hear you scream into your pixels?
Well, it's a keyboard cable :cry:
Thanks, mrk for the recommendation. I was wondering what to replace my keyboard's default cable (which is black) and spotted your post! :)
A new printer - I never knew portable printers existed.
I owned an Epson inkjet, and it was horrific, chewed through ink. I only want to print a few documents, so a minimal footprint and one that can be packed away is ideal. I'm not expecting miracles, if the print quality is half decent then I'll be happy.
  • Like
Reactions: mrk
That noisy owl is back. Already hooting and it's only 20:00. Now I can hear a fox, must be some kind of meetup going on.
Bought a cheap 'refurbished' Lenovo T480. Ordered some more RAM and a bigger SSD to go in it and I'll just use it as a little dev machine to play around on.
Good choice. I've had mine a few years, upgraded to 32gb RAM, various different batteries including a couple of extended ones, and two SSD's (if you get the right SSD you can add one to the WWAN slot but not all are compatible). It can also run an eGPU as it has Thunderbolt, although the CPU is a bit weak for any real games.
