Which b650m mobo
13 Feb 2016
Building a new pc for graphical and streaming work
Spec so far ryzen 9 7900x, 64gb ddr5 5800 ram, rtz 4070 super gpu
However cant decide which mobo. Choices are:
Asus tuf b650m plus wifi
Asrock b650m pro rs wifi
Msi pro 650m-a wifi
Budget £150
Thanks for looking
The Asus tuf m is £179 so it rules itself out if you budget is £150 . 7900x you may want a better board with more power phases if your loading the CPU for a long time.
Out of the other 2 I would take Asrock b650m pro rs wifi it has 1 extra m2 slot and the main m2 slot is pcie5.
The B650M MSI mortar was the only one I would have considered personally around that price due to VRM features.
