The marketplace is fundamentally different to what it was in late 2022 and that pricing structure was an aberration, that won't fly again.
You're underestimating the FOMOcels, who will be happy to hand over their hard-earned cash once again, because one simply can't enjoy a game without a 5090 and pixel creep.
Yes, because it uses 2GB ICs...This is why you can have 8 or 16gb on a card with a 128 bit bus like the 4060ti but you cannot stick 12gb on there.
I don't really pay any attention to the 90 class and its effect on the GPU market below it.
Forums like this amplify their impact way beyond their actual effect, when they're really only a tiny percent of the GPU market, that only appeal to the very few.
I'll eat my hat if nVidia release the 5080 below $1k.
I doubt they'll have 3gb chips ready at launch though with is probably why the 5090 is being rumoured with a 512 bus and 32gb and not a 384 bus and 36gb, it'll need 16 VRAM chips which will be difficult to fit all on one side unless the chips are smaller.Yes, because it uses 2GB ICs...
"With 3GB ICs, the RTX 5080 would be able to offer 24GB of VRAM without adding or reducing the memory chip count, enabling it to retain its 256-bit wide interface. Depending on how Nvidia wants to operate in the age of GDDR7, it could also play the same trick with the RTX 5090 and give it 48GB of memory with 3GB ICs."
source
"But on top of that, 24Gb GDDR7 chips are also going into production, for which the effective capacity would be 3GB per chip. And that will allow for graphics cards with 50% more memory capacity. So in addition to the previously cited numbers, it will also be possible to have 12GB graphics cards with a 128-bit bus, 18GB graphics cards with a 192-bit bus, 24GB graphics cards with a 256-bit bus, or a capacity of 36GB for GPUs with a 384-bit bus width. A clamshell design would double those again."
source
Edit: Sorry, I thought in your original post you were saying I was wrong about the 36/48 capacities for 3GB chips, which you weren't!
It doesn't but it makes it more difficult to cool when they're on the rear as was the case with the 3090.does it have to be single sided? Chips on the back might add a teeny bit more oomph to the '2 slot cooler' rumour
you should care because even if you are not in the market for that tier/product it acts as a price anchor which influences the prices of the segments you are interested in. Nvidia segments the product lines from the top down not the bottom upI don't really pay any attention to the 90 class and its effect on the GPU market below it.
Wow, those are some bitter words right there!You're underestimating the FOMOcels, who will be happy to hand over their hard-earned cash once again, because one simply can't enjoy a game without a 5090 and pixel creep.
Wow, those are some bitter words right there!![]()
No release date and no confirmed specs or prices
