Hi all,
We've finally got around to decorating the living and dining room of the house we've been in for a year.
The radiators downstairs are interestingly positioned, most of them are butted up against the wall, something I haven't seen before as usually they sit an inch or so from the wall on their brackets.
Annoyingly this means the pipes (coming up through concrete substrate floor) are either butted up against the skirting and in once instance, there's a semi circle recess drilled into the skirting for the pipes to fit.
Is this a known configuration for the rad the be directly on the wall? Or a bodge job? Usually I would take the rad off but I can't isolate it as the TRV pin is stuck open and I can't seem to loosen it.
I'm asking as it might be beneficial to move the rad away from the wall with an offset pipe fitting? After removing the wallpaper around this pictured rad, there's a clear dark patch above it.
Many thanks in advance
