- 11 Mar 2023
- Bristol
Hi.
I built my new pc today (not the first time) and ran into a problem.
I turn on the pc and there is no display and the MB beeps three times. Looking at the manual this means a system memory problem. I have checked to make sure it's in the correct channels. Taken one stick out and swapped it around etc but it still continues to beep no which stick is in.
Does this mean there is an issue with the RAM or something else? Surely both sticks can't be bad? I have double checked and the memory is compatible with the mb.
I sadly do not have any more ddr5 ram to swap out and check if it's that.
Is it possible that two sticks are doa?
Thank you for any help as I'm panicking a bit lol
The mb is an asrock.
