Are you sure there is not a metal lintel which is hidden under the mortar or trim?
There are no cracks or viable sagging so it’s probably fine.
P.S. that wonky brickwork is triggering me but in terms of whether you need to do anything, probably not.
Where are the weep holes?
Don't think it's funny really, it's leaving me in a very difficult position.
The quote is way overpriced but I'm stuck if I can't find anyone to do the work.
wouldn’t take off any more than you need to. It may be just ugly blocks behind it. If there is no obvious DPC bridging, I would leave it as it is. If it ain’t broke, don’t fix it
Your air bricks need to either be raised or the ground/pavement lowered the pics on the 1st page show them level with the ground.
Anyone used Stormdry or similar breathable waterproofing creme? It's expensive but seems to get very good feedback from a range of professionals. I'm thinking of using it on my low level brickwork where the gap to the dpc is insufficient, to help things.
Once cleaned up and repointed I think it will end up looking loads better than that render![]()
What was underneath the render? Yep you guessed it, more painted bricks. Red this time.
They also make a tool for that:You can make an icing bag so you can squeeze the mortar into the gaps and get it right in there.
Removing the door and windows will likely give you lots more work if the mortar is as bad as you say, necessitating rebuilding of walls.
Yeah no chance I'm going to attempt taking the doors and windows out. Whenever they are replaced would be the time to do it properly, probably won't be during my ownership.
I'm hoping to replace a couple of the worst bricks tomorrow, and repoint the rest. Also swapping two airbricks. I have to leave the one in the middle as there is a central heating drain sticking out of it.
Eventually I will build a step in front of the french doors so I wonder if I can ditch that middle airbrick? Surely two on that section of wall is enough?
