- 9 Dec 2009
- Bristol
Where ever I've been, I always have to go back 2-3 times because they don't get the steering wheel straight :/
I had that on one of the Mrs's cars, before I learned a little bit about alignment.
The car did feel slightly wayward, so when I took her car in to a tyre place to get two tyres replaced I took them up on their offer to check and adjust the alignment.
They did the tyres and alignment and the car did feel fine, but after the Mrs did a few trips she said she'd noticed the steering wheel was wonky.
I hadn't noticed but sure enough it was, just a bit.
I took it to a dedicated alignment specialist and he took me under the car to show what happened. One of the tie rod ends had seized, so they'd left it and forced an over adjustment on the other side to get both sides of the alignment machine out of the red and into the green for toe.
With a bit of heat he unseized stuck side and adjusted the toe properly.
I don't really blame the tyre fitters, they're probably pushed to offer these extras and though they have a machine they are not alignment experts and just move things back and forth until everything is in the green.
Needless to say, since then I only use an alignment specialist for our cars.
