- 25 Oct 2005
I've got an MSI Tomohawk x570 which has been running without issue for a few years. When I first got it, I had an issue with the chipset fan running at full speed. I can't really remember the details of what fixed it but I do recall it being a common issue.
A couple of months ago I had left my PC on for a while, came back in the room and the chipset fan was running at 100%. I turned off and on again, and all was good. Now this has happened twice in the last two days. Restarting alone doesn't fix it and the BIOS, MSI Center and HWMonitor all tell me that the chipset is running at 127C, which is obviously wrong.
Any ideas on how to fix this? Worst case I guess would be to disconnect the fan as since I fixed the problem initially, I don't think I've ever heard it spin up. Or maybe I could hook the fan up some way to a fan header, either motherboard or Aquasuite controlled and then I could run it at a nominal (quiet) value? Or could a software fix do the job, maybe a BIOS update?
The noise is very annoying with the fan at 100%!
