Hi, I received my new AVR yesterday, the Marantz Cinema 60 DAB. It is to replace my aging Denon X2400H. Everything is very familiar as it is Marantz/Denon, and I ran through all the assisted setup at the start for my 5.0 setup. But compared to the Denon I appear to have literally no sound parameters to choose from.
If I use the TV and watch an HD channel, with my LG C3 set to output over eARC on "Auto", the Marantz lets me either select Stereo, Dolby Surround or Multi Channel Stereo. If I watch a non-HD channel, I get Stereo, DTS-X:Neural or Multi Channel Stereo.
When I had the Denon connected I had a myriad of options to choose from. And I'm pretty confident I remember seeing stuff like Dolby Digital+Dolby Surround, etc. I don't have any of that. With the X2400H, I used DTS-X:Neural for everything as I prefered it. It was louder and had more bass to the sound vs. Dolby.
Why does the Marantz not give me as many options? The amp assign was set to 7.1. I tried setting it back to the default which is 5.1+Zone2. Doesn't appear to make any difference. I checked the ohms were correct (8 ohm) as well. I plan to swap them back tomorrow and do some testing with some different source material (TV, Netflix,4K Blu-ray, etc). And compare notes.
The other thing I noticed is that, if I have the TV set to "Auto" or "Pass through" (no difference) for the audio when watching TV, the Marantz reports PCM (2/0/0). If I actually select "PCM", it is the same. Yet one gives me Dolby Surround and the other DTS-X. But the signal is always reported as PCM.
Finally, I watched Top Gun Maverik in 4k and I found the speech muffled and totally over powered by the effects and music. I've seen this film twice using the Denon and I don't remember that being an issue. Only difference being is that the Marantz said it was playing back in Dolby Atmos, which the X2400H can't do.
Not 100% convinced I'll be keeping it, but will test further tomorrow.
Cheers.
Cheers.
