Don
- 20 Oct 2002
- Oxfordshire / Bucks
Just about to report this
Granted but all that means is the photography equipment is a better investment than the GPU.
Unfortunately the rate at which each depreciates doesn't really affect how much they cost to start with. They're both luxury items and, as I said, are priced as such.
I don't think it's really comparable to other hobbies.
Most other hobbies have entry level products that are cheap and more than good enough.
GPU's don't have the competition needed to drive down prices, there's pretty much only high end now.
Also they won't hold value for more than 2 years, it's pretty much a consumable
Well... gamers could also stay at 1080p at 60fps or even 30fps, since most argue that graphics don't matter. But when you want 1440p or 4k alongside 100fps + and high details... then pay the price. Easy.
for me it would be the Cyperpunk 2077 DLC with path trancing @1440p ultrawide, no chance in hell of doing that at playable frames on my current RTX3090What games are use all wanting to try with the 5090?
I doubt it, as little to no modern game even supports it any more. I loved SLI, but at least for now it's a dead technology, plus with the size of modern GPUs you're going to either need one hell of a big case to even fit just two cards, or water cool them. And then there's the price where even the mid-range is ridiculously expensive let alone the top end ones. You have more chance of seeing the old AGP port coming back before SLI as we know it does.will nvidia bring back sli? it looks like sli is feasible over pcie 5 bus and you'd no longer need those expensive sli dongles
Funnily enough, with the slow increases in performance we've been getting it would actually make more sense than when the performance increases between generations were ginormous, though the VRAM capacity would likely be an issue.will nvidia bring back sli? it looks like sli is feasible over pcie 5 bus and you'd no longer need those expensive sli dongles
a bunch of games at 1440p hitting 480hz or whatever the game engine limit is for said game.What games are use all wanting to try with the 5090?
What's gonna happen now is, if this continues then more people will probably still be using 1080p screens or 1440p at a push and use lower settings to get good performance.Just look at when the RTX4000 series launch - RTX3060TI users upgrade path was a £580 RTX4070(up from £370),which cost nearly 60% more. The value is getting worse and worse even for a mainstream gamer.
The top end is less of an issue. Someone already spending £1600 on a new card,probably would care less about another £200 to £300 on top.
The issue is a combination of poor optimisations and having to push nicer graphics in modern games means even if you have lower expectations,the shrinkflation is not really helping there. For example an RTX4060 is barely 40% faster than an RTX2060 after almost 6 years. The RTX2060 was almost 75% faster than a GTX1060 and 20% faster than a GTX1070 in under 3 years.
Higher resolution coupled with faster light reaction would probably be better.Just boost ray count in CP2077
I feel the mum not dressed up as a bucket of spatulas is a missed opportunity.
Every now and then I realise some people are engaging with this hobby in a completely different realm to mea bunch of games at 1440p hitting 480hz or whatever the game engine limit is for said game.
a bunch of other games at 4K hitting above 60 fps and beyond natively with max settings ( CP 2077, Alan Wake 2)
even better if some games could do 8K 120hz even if it means settings reduced (Would put me back in the market for an 8K monitor/tv when one drops with 120/144hz support.
