I have never done this before and I would like to lower the total amount of Watts that the mobo can use while under full load.
I'm doing this because I want to Undervolt my CPU and I have also used Curve Optimizer,the problem is even going to 1.31 volts per core and also a -20 offset in Curve Optimizer and never seen any reduction with heat or power being used,I have also tried Eco Mode in the bios and it use's the same amount of Watts.
I remember watching a video where the guy said that you need to also limit the total Watts that the mobo can use but I can not find the video because he showed what you need to do.
Can someone please tell me where you go in the bios of an ASUS X870E ProArt to lower the total Watts the CPU can use.
