 - 4 Feb 2011
Get any decent 144hz 1440p/4K monitor and you'll be very happy even just for desktop usage.Here I am at 40fps on 1440p with a max 75hz monitor
Yeah...but that might push my 1070ti a little too muchGet any decent 144hz 1440p/4K monitor and you'll be very happy even just for desktop usage.
definitelyhis middle finger
I was thinking about going to the 5090 but I just can't really justify it and it would burn financially to spend north of 2k on a GPU... games will still look immense on the 40 series cards and even the 30 series cards for a good while yet.tbh I think a used and sensibly priced 4090 will become the new high-end sweet spot, sure if you want the fastest it isn't going to be that but its still going to be top tier for another generation imho we've not seen anything yet that suggests otherwise.
Define sensibly priced...tbh I think a used and sensibly priced 4090 will become the new high-end sweet spot, sure if you want the fastest it isn't going to be that but its still going to be top tier for another generation imho we've not seen anything yet that suggests otherwise.
Hmm I’m getting convinced that the 5090 will require two 12v cables… each requiring two pcie power cables. So same 4 cables as per the original octopus adapter… just split across two inputs.
That would 100% solve all the power issues, right?
All the 3.1 PSUs having two of these adaptors, and the ultra slow rollout of putting the 3.1s to market, is the giveaway. In what other circumstance would you ever need 2 12v slots in your PSU, but only one set of MV connectors…?
12V-2×6 Connector Replaces the 12VHPWR connector, offering up to 600W of power for high-end GPUs and components
