- 5 May 2004
- Northern Ireland
If placed on the landing upstairs, is it best to have it on continuous or aim for a targeted % value?You need to run it for like a week in 1 room in order to get all the moisture out of every surface. Everything is a sponge. If you just run it for several hours, and then turn it off. It is not going to be effective.
Also, if you are trying to just have 1 running, best place to put it is the landing, upstairs. Cloud rises, so upstairs will be more humid than downstairs. If you remove the moisture from upstairs, then it will force the more moist air from downstairs to travel up.
