Morning All,
I bought an TP-LINK AX5400 yesterday to replace my Virgin Media Hub 5 as I am constantly struggling with range and instability in my house.
I switched my Hub 5 into modem mode and connected the new router as per the instructions. Everything was set up and working well until I plugged in my ethernet cables. I have 2 ethernet cables plugged into the back of my Hub 5 usually. One of them is connected to my PC (~3 meters away) and another which is connected to my Reolink security camera NVR. This NVR is in another room to my router so I had to use a 25m ethernet cable to connect it previously.
It was working fine as it should on my Hub 5 so I know the ethernet cable is fine. Even within the AX5400 settings, it is not detecting this ethernet cable at all and it's behaving as if it's not even connected. So far I have tried the following to try and resolve this with no luck:
- Unplugged NVR and connected my laptop instead. Again, router behaves as if nothing is connected.
- moved NVR from the other room and plugged it into the AX5400 using another ethernet cable. NVR detected this and was working fine.
- Tried different ports on the AX5400, made no difference.
- Removed the new router and moved back to the Hub 5. Everything was working fine and back to normal.
I am assuming the new router is not liking the ethernet cable that connects to my NVR. I know the easiest thing to do is to replace this cable, but I would like to avoid this as routing a new ethernet cable to the other room will be a lot of work.
Any other advice on what I can do please? Otherwise I will have no other solution than to send the AX5400 back and try another brand.
Thank you!
Thank you!
