- 6 Apr 2009
- Exeter, Uk
Hi wondering if anyone could help,
I've just put a new build together (here) and everything is working fine except i'm getting no audio out from the rear panel audio jacks and no audio devices are showing in Windows11>Settings>Sound or the device manager (except my monitor which doesn't have a speaker). I've contacted Asus Support (see below) who seem to think I have a faulty motherboard and may need to return it.
Was just wondering if there's anything you guys could think of to try before looking to replace the motherboard?
Many thanks,
Mach234
Windows 11 Home version 24H2 x64 HB5044384
Asus Tuf Gaming B650 Plus Wifi
MSI GeForce RTX 3060 Ventus 2X OC 12GB GDDR6 GeForce Game Ready Driver v566.03
AMD Ryzen 9 9900x
Corsair Vengeance EXPO 64GB DDR5 PC5-44800C40 5600MHz
Speakers: Logitech z906 5.1 surround (connected via Asus motherboard rear panel line out/rear/sub jacks)
Hi,
Having problems with a desktop I have put together. It's up and running and everything is working well, windows 11 installed and up to date, all hardware driver updaters installed and run to install the latest drivers (Armoury Crate, AI Suite, NVidia GeForce Experience), all system diagnostics come back looking good: cpu, memory, storage, display, networks etc.
The only issue is there is no audio coming out of the rear panel audio jacks:
I have checked Windows11>Settings>System>Sound and it picks up my monitor but lists nothing else
I noticed in Armoury Crate>Tools>Drivers there was no entry for Audio Drivers, is this an oversight?
Since encountering the problem I have also tried:
* Installed Armoury Two-Way Noise Cancellation utility.
* Logged into my Asus account>Selected my registered motherboard product>Drivers & Tools>Audio>Downloaded and installed the Realtek Audio Driver v6.0.9700.1
* DTS Audio Processing when opened gives the message "DTS Audio Processing settings are unavailable as audio service connection lost".
* Realtek Audio Console opens but hangs on the spinner.
* I have checked Windows Component Services>Services>Windows Audio, which is running.
* Windows 11 Device Manager>Sound, Video, Game Controllers>AMD High Definition Audio Device (Advanced Micro Devices 10.0.1.38) is running properly (as is NVidia HD & Virtual Audio)
* Windows 11 Device Manager>Audio Inputs & Outputs only lists my monitor
If you could please let me know what you think might be wrong, the next thing to try, or let me know how to get any log files you think would be useful in getting audio to the rear output jacks, it would be really appreciated.
Many thanks,
Thank you for contacting the ASUS UK Support Team.
It would be my pleasure to assist you in any way possible.
The jack ports are simplistic interface, mainly 'plug-and-play' orientate, thus there are no advanced troubleshooting steps or log files that can be extracted.
To confirm that there are no driver related faults regarding this, the easiest way would be to use the front panel (if your case has jack ports) or an USB audio device.
According to the error symptoms you have described, we unfortunately have to assume that you are dealing with a hardware error. Although we manufacture our products to the highest possible standards and aim for them to function well beyond normal life expectancy, at the end of the day they are highly complex technical products that unfortunately can on occasion encounter a hardware malfunction.
We are sorry that this appears to be the case with you. Since we do not offer direct service processing, we would recommend that you report your device to your dealer. They will then take over the further processing for you.
I understand this is inconvenient, as part of the sale process the reseller/retailer accepted that they would control all returns/replacement on behalf of ASUS for the duration of the warranty.
I do hope this has been some help to you.
Many thanks,
Mach234
AMD Ryzen 9 9900x
Hi,
Many thanks,
I think you'd need to research some specific advice for that, or ask the manufacturer, 'cos I've never heard of anything like it.
