Best value mini-pc/client for Moonlight 4K/120hz
1 Nov 2011
Portsmouth
As title, I'm trying to figure out the cheapest/best value way to stream games (Sunshine/Moonlight) from my study PC (5900X, 7800XT) to the lounge or bedroom TVs (TCL 845K), at 4K/120hz. House is wired with Cat6, but have very decent mesh Wifi6E, too.
The TCL TVs will run Moonlight natively (Google OS), but I can't access game mode (120hz) without using one of the HDMI 2.1 ports....
Could use an Xbox One S = £120ish each, but they're bulkier than I'd like.
Some sort of all in one mini pc (NUC) that I could hide behind the TV would be ideal, but I'm struggling to find ones with HDMI 2.1 4K/120hz for anywhere close to the cost of an Xbox.
Anyone had any success doing this?
Is hdmi over ethernet an option depending on your cable set up? Actually not sure if you can do that with 2.1...never looked
It wouldn't be streaming, but would certainly avoid a lot of the other niggles that come with Moonlight/SteamLink...
4k/120hz HDMI 2.1 over Cat6/7 distro boxes are very pricey (£380+ based on a quick search).
But a 30m HDMI 2.1 fibre cable is a potential consideration - £55 from Kenable. I just need to test whether my PC will pick up my controller's signal from the bedroom/lounge. I have a few which use Bluetooth and/or 2.4Ghz dongles (PS5, Xbox E2, EasySM-X15 + a few others), so I'm hopeful.
Will report back.
Thread watched ;)
I’ll be buying a 4k 120hz Tv soon, and looking for alternative to fireTV 4k stick for Moonlight
Problem is I have always had problems with HDMI outputting 7.1 sound from non set top boxes (such as windows PCs). You actually tried a Xbox One S to do 4k 120hz?
Thread watched ;)
Google-Fu results, so far:
Xbox One-S will do 1440p, but only at 60hz.
A Series S will do 1440p @120hz.
Series X will output 4k 120hz.
Still looking for a budget friendly solution that offers an HDMI 2.1, 4K @120hz output. Lots of recommendations for Minisforum tiny PCs, but not at a price below that of a secondhand Series S.
Pretty sure it's going to be a 30m HDMI Fibre cable, with a possible matching length USB 3 extension, to plug the controller's dongle into...
Which means I'm just using the TV as a second monitor, rather than streaming over ethernet.
Honestly though, what games are you playing?
If you're playing with a controller anyway on said tv, you'd probably just be best buying an XSX and using that natively on that TV? Seems like a big expense for a streaming box and it still wont 100% feel as good as native either.
Or downsize any pc you have to ITX and just move it into the space with the TV when needed?
The shield TV Pro seems like it should be decent at this and as a bonus, is probably the best media playback device/jellyfin client as well. I've got one, will try and fiddle with moonlight.
I've got ethernet running from my loft conversion with the pc in to the shield 2 floors below it. I guess I'd need to use the software to connect my controller to the shield as it will be out of range to connect to the pc
Edit: 4k 60hz only
Xbox One-S (not Series) confirmed running at 1440p, 120hz, averaging 6ms latency.
Can also have 4K, 60hz with HDR, Dolby Vision etc, but this doubles the latency (12-14ms). For the games I play (single player, Tomb Raider, Days Gone, Cyberpunk), it's perfectly tolerable and looks fantastic.
I did have to connect the Xbox directly to the TV (TCL C845K) with an HDMI 2.1 cable, rather than going through the AV Receiver, which is limited to 60hz, but I still get decent sound via eARC.
My son plays Fortnite & Rocket League tournaments (pretty successfully, to be fair) and he said the 1080p 120hz at 2-4ms "isn't that bad" and could be great fun playing on the 75" screen & 5.2 sound system.
I'm certainly looking forward to some evenings on the sofa as I work through the huge backlog of games I've bought, but not had time to play.
A Series-X would obviously be better for a 4K/120hz client, but I already had a spare One-S in the cupboard, so this exercise has currently cost me absolutely nothing bar time fiddling with inputs & settings.
I hear you.
I've waited years to have my own space/study, where I can use my PC for work & "Dadmin" in peace, but I don't want to shut myself away from the family completely.
This exercise gives me the ability to play my huge game library in the comfort of the lounge, without the noise & heat of the PC in the same room (which we had in our tiny old flat, where every square foot had to be multi-purpose...), but I can still escape to the study for a conference call or watch an Inquiry hearing/Commons debate, without having to shift hardware around the house each time...
A bit of a bump - I'm at the same point, but can't route an HDMI cable between the two (I've got some cat6 cables in the walls, but they're all already in use for various things); has anyone any suggestions?
My Dad needed a new PC (non-gaming, mainly office work and managing a few AM/LW radio apps), so I ordered a Beelink EQi12 with Intel i5 12450H (10C/16T), 24GB DDR5, 500GB PCiE4.0.
It came with Win11 Pro already installed for £299 delivered.
I set it up in my lounge with HDMI output to my TV (4K, 144hz TCL C845K).
I thought it was only 60hz, but Display Settings let me select 4k, 120hz.
For use as a Moonlight client, it was absolutely brilliant and I'll be getting myself one next month.
An interesting thread. I don't have need for remote gaming per-say but do have separate 4K and 2K screens for my PC and consoles.
I know you've answered your requirement but my immediate thought was a Steam Deck given that aside from streaming you get all the wonderful benefits of a handheld. But even with the official dock there seems to conflicting info on whether it can do 120hz/4K over DP. However the Lenovo Go, Asus ROG Ally etc. should all be capable of it it seems. And they both have official Steam OS support coming too.
Huge fan of the Minisforum and Beelink mini PCs. I've had the Minisforum UM480 which I've been running as a daily PC (Linux Fedora) for just over a year. My only complaint is dust can get trapped in the top half and I can't work out how to get it apart fully. So have to give it a good clean with compressed air but this does sort it out and only needs to be done once or twice a year.
Official Steamdeck docs states 4k at up to 60hz and 1440p up to 120hz, via DP, and only has an HDMI 2.0 port.
The Benq beCreatus GR10 dock states 4k at 120hz via its HDMI 2.1 port.
