- 14 Jul 2005
- Birmingham
yes correct and that is exactly what condensation is - moisture coming out of the air near a cold surface because the air has more moisture in it than it can hold at its new suddenly lower temperature.Quickie (and possibly theoretical) - If RH reaches 100%, does that mean that the air cannot hold any more moisture and will start dumping it out as water if it gets any higher?
Ha - yes your first one was completely correct.What paragraph are you referring to?![]()
