Power tools battery interchangeable compatibility?
IC3
IC3
3 Dec 2011
Are there any brands that have interchangeable batteries, or is everything different? I'm aware there're adaptors, but that's not what I'm looking for.
Theres CAS which have a few brands on there but they tend to be ones that don’t compete with each other.
Good brands like fischer and metabo are there as well as high end mafell and rothenberger
Apart from that it’s adaptors i’m afraid. Which is probably the way to go to get the best off all worlds.
  • Like
Reactions: IC3
Thanks, I'll take a look, its crazy that some brands have different battery systems specific to a particular product range... They should put in industry standards that the companies have to adhere to.
Yup, climate change and what have you. Realistically companies don’t give a ****.
  • Like
Reactions: IC3
