CAD Build
9 Feb 2009
Sunny Fife
Hi,
I'm looking to build 2 or 3 PC workstations to use with Solidworks and EdgeCAM work, my boss asked if I could take a look around as we need to upgrade. I've built quite a few gaming systems over the years but never a workstation.
I was thinking -
i7 14700k- not set....I know nothing about intel so I'm open to AMD suggestions too.
Asus TUF z790 Gaming - not set....I know nothing about intel so I'm open to AMD suggestions too.
64gb 5600 RAM
Nvidia RTX 2000 ada series (seems to be the best fit for what we do)
Phantom Spirit cooler
512gb m.2. boot drive
2tb m.2. storage
1000w corsair PSU
A plain looking case something like Fractal Pop Silent? This is for an office so no RGB needed.
We currently run SW 2016 but will probably upgrade to the new version soon, usage is nothing crazy but loads of rounds and some surfacing is stressing the old PC's we currently have out. EdgeCAM is from 2022 and really needs more grunt for counting all of the toolpaths.
Looking somewhere around £2-2.5k.
Cheers in advance for any help.
The AMD 9900X is a good all-rounder option with consistently high performance in single and multi threaded apps. The 14700K is not a bad choice except for the fact that we don't know if these CPUs are truly fixed. If you're happy to rely on the 5 year extended warranty then it is not a big deal, though at this point I'd be inclined to get the Ultra 265K if wanting to go Intel, since the major weakness of this CPU (gaming) doesn't apply for your use case.
You'll likely need to mess with the fan curves and possibly the power limits too (depending on the BIOS used) to get this comfortable with a 14700K.
My basket at OcUK:
Total: £2,154.77 (includes delivery: £11.98)​
I wouldnt touch a 13th or 14th gen intel chip whne AMD are more than equla to them in CAD and dont have the possibility of frying themselves.
Additionally the RTX2000 cards and similar are just rebadged versions of the gaming card basically, there is so little between you are much better off getting a 4080.
We have AMD 7950x chips and RTX 4080's in machines at work for use with Navis, Autodesk and Sketchup.
My basket at OcUK:
Like I said I dont have a preference for AMD or Intel, basically not a clue lol. If you were to pick what would you go for especially if Intel might blow up at some point, I can't see me being very popular if that happened. The 9900x sounds pretty good after a quick bit of reading.
I see the A2000 ada card for £624 online so going to a 4080 seems like a bit of a leap price wise, gaming on these will be absolutely zero.
The spirit cooler was just because I use one at home and have been impressed with it on my 7800x3d, again if there is a better way please feel free to say as I don't want to muck this up.
Thank you both so much for your comments and help so far, it is very much appreciated.
Personally I would just avoid the 13th-14th gen CPUs, since there's no need to take the risk. The Core Ultra CPUs are fine, so far as we know.
Something like the AMD 9900X is a good choice, no worries there.
The 265K is roughly comparable to the 9900X in most workloads, so if you prefer Intel that would work. I'd just take whatever has a good price, but the AMD AM5 platform is more mature and performance is more consistent. Intel is going to need some BIOS/software updates (they've said they are coming) to smooth out the rough edges.
There's nothing with buying a peerless assassin/phantom spirit, but you might have to fiddle with it, that's all.
Magic, thank you so much. At least I have a few options to throw at them on Monday.
Would the cooler be ok on the AMD chip, guessing it is just the Intel one that runs hot at full tilt?
I'd expect a bit of tweaking to be necessary with either CPU, since in TPU's review their power profile was pretty similar and if anything the Intel ran a bit cooler:
Well I put the two builds forward and it looks like we are going 9900x.
Thanks again so much for the help, it is appreciated so keep up the great work.
