Hardware advice needed please for Adobe Software
11 Feb 2007
Hi all.
It's been some time since i build a pc and I'm bewildered by the options and lelvels of power hardware comes in these days.
I'm really hoping some tech guru can help me out here.
My PC is knocking on a bit and I'm about to subscribe to the Adobe Crative Cloud, mostly for photoshop, Illustrator and Acrobat.
However, I'm not sure if my PC can be upgraded to be suitable for the software.
This is my setup below and I have also posted a link the the Adobe software spec.
My PC Spec
Adobe software spec
Can anyone advise me please?
Could I upgrade the Graphics Card, RAM, SSH or is this PC (motherboard) just not up to it?
I really look forward to your advice.
Thanks
Andy
Why not just post your current spec on the thread ... people may not want to follow unknown links.
Do you *need* Adobe ? Is it actually required? or are you wanting something to simple edit photos?
Personally, I wouldn't subscribe to it anymore, I dont think its value for money.
There are other software options out there which are considerably less outlay moneywise overall and offer the bulk of the features that Adobe has ( Affinity Photo / Designer / Publisher Suite for example ).
As for specs ... any modern 6 core or more CPU, 16GB ram ( preferably 32GB ), any nvme drive, and a GPU with 8GB of VRAM would likely see you fine.
or buy a mac mini m4 with a 512GB storage upgrade and call it quits ... as that would run all that you need in a tiny package.
Yes, you're both right. I uploaded a screenshot from my pc using speccy which creates an image of my pc spec.
I'll post just the spec a bit later when I'm working on my pc.
Good thinking guys because I really do need some advice on this.
Thank You
Andy
Here it is:
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core i5 3470 @ 3.20GHz
Ivy Bridge 22nm Technology
RAM
16.0GB Dual-Channel DDR3 @ 665MHz (9-9-9-24)
Motherboard
Dell Inc. 084J0R (CPU 1)
Graphics
VX2235wm (1680x1050@59Hz)
Intel HD Graphics (Dell)
1023MB NVIDIA DeForce GT 620 (EVGA)
ForceWare version 388.13
SLI Disabled
Storage
465GB Seagate ST500DM002-1BD142 (SATA)
465GB Crucial CT500MX500SSD1 (SATA) (SSD))
279GB Seagate Expansiob Desk SCSI Disck Drive (USB)
Optical Drives
TSSTcorp DVD+-RW SH-216DB
Audio
High Definition Audio Device
To be fair your pc is old and it would probably be best to build something new but that depends on your budget.
What's the most demanding thing you do on your pc
Th most demanding thing is working with Photoshop. I could build a new PC bu my budget is the issue hence t he reason to see if I can upgrade my current one.
I've built PC's but years ago and things have moved on so much. I wouldn't even know where to start regarding Motherboard, CPU and Grapgics Card, etc.
Adobe Photoshop system requirements and e stated on there web page, but as for the cloud stuff I don't know.
A direct x 12 GPU is required so you may be able to upgrade you GPU but that will depend on your PSU.
I'm going to tag a few members in that may be able to help you further.
@Tetras @tamzzy @Quartz @Journey @JollyJamma @freddie64
Thank you mickyfinn - that's very much appreciated.
I really don't understand the hardware anymore.
The actual pc is a DELL Vostro 270
If there is a more up to date and capable DELL PC i'd probably go for one of them (used of course) because I've had no problems with it at all.
I would strongly recommend you go with a non mass produced machine (ie not Dell or HP) as custom machines are as good and more flexible with upgrades down the road.
You'll need to give us a budget first before we can say anything.
Your PC appears to be meeting the minimum requirements. What makes you think it won't work?
Looking at your spec, I feel it would run a lot of Creative Cloud. Where it won't be adequate is for some of the new AI tools. What are you going to be doing with Creative Cloud?
I have an i5 laptop with 16GB RAM and it's running CC, but not the latest versions of Photoshop and Illustrator as it won't do the AI stuff.
Hi Radderfire - I will really only be using Photoshop, Illustrator and Acrobat, but I do remember seeing a notification about my graphics card not being up to the job. I'll have another look at it and report back. Thank You
Try using your current rig for the workload and keep an eye on system resource monitor and see which components have 100% usage - I'll be surprised if your RAM and CPU aren't at full usage.
Even a basic midrange PC will have a significant improvement in performance over your current system - for example, a 12400F, Z690 motherboard with 32gigs of DDR4 RAM and a 1tb SSD would be really really quick and not that expensive.
You could also consider a mid-range AM5 system - e.g., 7600X, 32gigs of DDR5 6000, B650 motherboards would be great.
Your computer will run Adobe. The question is how quickly. And how much effect a slow workflow affects your productivity.
If using Adobe is for a hobby and not time critical then no need to upgrade if the current specs serve your purpose.
However if it's for work and affects your income then the faster the computer, the more work done/productivity you'll have - in this case, then an upgrade is more than warranted.
If the graphics card isn't good enough a GTX 670 2GB or better should be enough. £30 ish. Nvidia is very slightly better a few Photoshop processes can use CUDA, not sure how much benefit it will give.
You'd need to check if your PSU is up to the job with power output and connectors and it will fit inside the PC. If it doesn't then newer GPUs of the same performance have lower power requirements and be physically smaller, but cost a tad more. GTX 1050 2GB. £40+
You should be able to get a free trial with Adobe to see if you PC works before upgrading.
So I purchased a used EVGA SSC GEFORCE GTX 1050Ti Graphics Card DDR5, fitted it an all works.
So now I'm looking to replace my very old Viewsonic VX2235wm (2006) :-) with two monitors.
I'm thinking of two 24inch rotate ability and again I'm on a tight budget.
I'm not a gamer, but need them for web developing, graphics, etc.
Any ideas guys please?
Am I correct in saying that the dpi1.4 connection on the graphics card will allow me to conntect two monitors with one split cable? and is this the best method?
It was so much easier in the old days :-D
Many thanks for your help.
Andy
