PCIe 5 GPUs in PCIe 4 Slots
16 Apr 2014
North East, UK
Given that the 50XX series are rumoured to land with PCIe 5 support, do we expect there will actually be much benefit to swapping to a PCIe 5 board?
As far as I'm aware, current GPU's aren't really maxing PCIe 4 slots? With that, my presumption is that the 50XX series will likely (although obviously unconfirmable) suffer no issues in a PCIe 4.0 slot.
If it's anything like a 4090 in a pci-e 3.0 slot, then it's likely a 2% loss at most
Interesting, didn't realise it'd be that little for PCIe 3.0!
As a Asus motherboard manufacturer employee on commission yes you have to upgrade, buy the most Asus expensive model and several spare just in case they're selling fast only a few left.
:D
Discount code? :P :P
Yes, because many GPUs are going to be x8 cards.
All the leaks/rumours are pointing to 50 series being x16 cards. Curious to see if AMD follow suit!
I mean 2% is kind of a lot no?
The problem is there are no PCIE Gen 5 micro-atx boards for AM5 that aren't server boards or out of production :(
I like my m-ATX case and I don't want to go to itx...
Not really, you'd be hard pressed to detect that in normal use - it's within the margin or error of most benchmarks.
Even the variation between different brands of the same graphics card can be more than that allowing for factory overclocks and different coolers allowing more boost.
On my old setup my 7900XT would only connect at PCIe 4.0 x4. I can't tell ANY difference with PCIe 4.0 x16 now I've changed motherboard, either with my eyes or with synthetic benchmarks.
Interesting, I would have thought that would have noticeable impact on GPU bandwidth! Although I think that gives around 8GBPS bandwidth for Gen 4.0 x4.
PCIe 4.0 4x is the same as PCI-E 2.0 16x, as per the link above even with a 4090, the loss is only between 8% and 18% depending on the game/settings.
What's more, I've found that mobos have the biggest variances in quality and features of components. Sticking with a good, solid platform is worth a lot more than moving to a notionally, marginally more performant one when you risk getting a dud or a something that doesn't fit your needs. I've "upgraded" mobos quite a few times only to find the newer platform is more unstable or just doesn't work as well as the old one, the detractions of which completely superceded the benefit of having <2% better performance in a few scenarios.
