- 5 Nov 2024
- Oxfordshire
When it comes to case fans/coolers, i tend to buy Popular cheap brands that you wont find on OCUK as i like to spend as little as i can and dont care for brands as long as it does what its meant to and so, if i cant find the solution to my ram dilemma, then i will get an AIO at some point.
Im eying up a brand that i use their case fans from which im happy with, but cheap or the big brands, i was curious if the AIO are made to the same quality or better quality than their air cool options?
