22 Dec 2024 at 19:03 #1 Vakas Vakas Associate Joined 8 Apr 2009 Posts 1,880 Location Manchester After upgrading my PC. motherboard, memory processor I can't get Windows 11 to activate, I ger error code, 0xc004f211 Will I need to purchase a new key?
22 Dec 2024 at 19:15 #2 ED209 ED209 Soldato Joined 5 Nov 2014 Posts 9,469 Vakas said: After upgrading my PC. motherboard, memory processor I can't get Windows 11 to activate, I ger error code, 0xc004f211 Will I need to purchase a new key? Click to expand... If your license key is an OEM 1 then its tied to the first system you activate it against. If its an retail key you can move it between systems.
22 Dec 2024 at 19:44 #3 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,880 Location Manchester I cannot remember, although I am sure it is retail Is there an easy way to check?
22 Dec 2024 at 20:02 #4 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,880 Location Manchester Vakas said: I cannot remember, although I am sure it is retail Is there an easy way to check? Click to expand... It's retail, had to sign in to my Microsoft account and it worked
