Man of Honour
- 16 Jul 2009
- Edinburgh
Not a new build but I've been downsizing my case; had a tiny motherboard in a huge case after an upgrade a couple of years ago and with a desk move was looking for a smaller footprint.
The machine has been working perfectly for a couple of years now
I've taken this kit:
B550i Aorus Pro AX with a 5800X3D CPU
ASRock 6900XT
64GB Corsair Dominator RAM
Various Drives
and moved it into a Cooler Master NR200P Max V2
Now the new case has a built in AIO and CPU (850W) which is more powerful than the old 750W anyway and the AIO seems to fit fine.
However when I turn the machine on everything "seems" to get power; AIO fans kick on, the GPU lights up (its RGB) although only the middle of the 3x fans kicks in and the other case fans also seem to get power.
But I'm getting zero display output at all, just a black screen (monitor remains in Stand By) and not even a post screen.
I'm at a bit of a loss as to where the problem could be; my CPU doesn't have an iGPU so I assume my trying to use the HDMI port on the motherboard is a waste of time; the GPU was working fine before and seems to be getting power so I think its probably ok.
I'm thinking it must be either motherboard related or the CPU (as it doesn't seem to boot despite power working) but I'm not sure how to check any of it and was looking for a little advice!
ASRock 6900XT
Various Drives
