Please can you check this build?
Caporegime
12 Mar 2004
England
Basically my computer was stolen so I need a new one but I'm very out of the loop on what's the latest cpu generation what motherboard chipsets support which features etc. I realise that a B motherboard doesn't support overclocking, but the CPU is still significantly more powerful than the lower end non overclockable one, and I made sure to get a SSD with TLC nand memory and not QLC! This is just an illustrative example, some of the components will be bought second hand and will be a different version. But is this build compatible with regards to the components used?
My basket at OcUK:
Total: £717.92 (includes delivery: £0.00)​
Main use is going to be photo editing and gaming. Budget is fairly minimal really, about £700, I'll probably be looking to get some components like the GPU used if possible.
Yeah wasn't sure about the PSU as I hadn't heard of that brand before, will look at a more reputable brand like Seasonic.
3800x , b450 motherboard, 16gb ddr4 in the members market if your interested, would offer £120.
This! Don't skimp on the PSU. Has the potential to damage other part sin your system. If you buy a decent one should last you through a couple of upgrades too hopefully.
+1! A high quality PSU will last a decade - maybe longer. Crappy PSUs blow up in a few weeks and usually nuke something else when they pop.
I used this in another thread and I'm going to use it again...
