- 19 Oct 2010
Thank you. i'll give that a spin.
Is it much better than Handbrake? That's what I use at the minute.Can't go wrong with
ffmpeg -i bigfile.mkv -c:v libx265 -crf 23 -c:a copy -c:s copy -o smallerfile.mkv
or to do a whole load of files one after another, cd to the directory where they are, create a new folder called encoded, and run this command
for %i in (*) do ffmpeg -i "%i" -c:v libx265 -crf 23 -c:a copy -c:s copy -o "encoded\%i"
Google ffmpeg to find that and how to install it, needs to be run from a DOS prompt, and path to the ffmpeg,exe file needs to be in your PATH environment variable.
I was quite disappointed that my LG G4 still only had a 100Mbps Ethernet port.What really bugs me with my latest approach is UHD stuff often goes above 100mb and my TV and indeed loads of them only have full speed rj45s sockets. I'm trying to limit my WiFi devices. Wish they'd put gigabit sockets on them.
So some of my UHD movies transcode to lower the quality.
I haven't found any that have faster, I wish they'd at least work with USB ethernet adapters.I was quite disappointed that my LG G4 still only had a 100Mbps Ethernet port.
Forgot to add, if you have LG oled you can play DV and HDR on Jellyfin app.Never tried Plex as always used Kodi. Last 6 months or so been using Jellyfin no problems at all on my Unraid server. Using Tailscale to share with family and also no problems.
Another long time Plex user here. Just got up to 100Tb storage. Runs flawlessly on a Synology DS920+ with 3x two bay USB3 DAS, all running in RAID1 so about 50Tb of actual usual space.
I attached a USB hub to it today, so I can add more external drives. Worked perfectly! It's a great little device.I'm 920+ as well. 10+ users. "only" 27.3tb usable though.
I'm doing the same soon with a Lenovo SFF system and a large HDD for media, I was considering Plex but jellyfin seems like it could be a better option. But then there's also Kodi.My set up is a biostar J3060 board integrated gpu. Switched to a smaller case with built in laptop brick style PSU last month. Running Xubuntu
All our TVs have the app, as do the tablets. It is better on Roku though.
Have it set up
Films
Series
Kids films
Kids series
Stand up
It's good, get the odd wrong cover and have to fix manually every now and again.
Very subjective, but I suspect in a few more years it’ll be dead.
Agreed, then the movies you want to watch are always on the service you don't have or cancelled last month etc.On the contrary, I would say self-hosting media is picking up again. It was different 5 years ago when you pretty much just had Netflix and Prime to subscribe to for your films and TV shows. But these days the half a dozen TV shows you want to watch all seem to be hosted by different providers making it a very expensive commitment.
Yeah, and some of the bitrates are laughable.On the contrary, I would say self-hosting media is picking up again. It was different 5 years ago when you pretty much just had Netflix and Prime to subscribe to for your films and TV shows. But these days the half a dozen TV shows you want to watch all seem to be hosted by different providers making it a very expensive commitment.
It depends, for me Plex doesn't handle surround at all its set to passthrough.Anyone have experience with plex and audio formats? Does it handle surround?
