- 2 May 2011
- Woking
Boilers turn off if the return temp is too close to flow temp or if the stat tells it to.
If the rads are actually hot (are they very hot or just warm?) then they still should be dissipating heat into the room.
You say you upped the flow temp setting, has this helped or not?
It's weird because I spent ages balancing them, even though they're ****. So the return temperature is relatively low - as low as you're likely to get it without having better kit.
I made a few changes so I don't know whether changing the flow temp helped. I will check tomorrow.
Unless I'm completely missing something you have ambient temp and target temp.
Ignoring opentherm etc etc
If it's 16 and you want it to be 21, your boiler is sending heat out at the flow temp until the thermostat hits 21 and then it stops sending heat.
Where is your thermostat? Is it in the coldest room?
Thermostat is in the same room where I'm monitoring the temperature.
following other current thread on boilers - this boiler modulates 5:1 https://professional.vaillant.co.uk/specifiers/products/ecofit-sustain-25-30-and-35kw-48448.html
so minimum output maybe 5Kw ... and if the house only needs ~3 say, like other thread - it will switch on and off.
eg. on for 6 minutes off for 4
That's what I set to Automatic, though i'm not sure that I trust it. The installer had set it to 18 kW!
So according to Google there's lots of reasons a boiler could short cycle.
It might be worth getting someone in to service the system OP.
Yeah I saw that. Quite annoying. I don't really trust plumbers tbh, maybe a heating engineer. It was recently serviced.
