No Display on ASUS ROG Strix SCAR 15" 3070 Ti Gaming Laptop
19 Oct 2002
Pembrokeshire
I used my gaming laptop this morning (an ASUS ROG Strix SCAR 15" WQHD 240Hz i9 RTX 3070 Ti) this morning plugged into my PC Monitor (very rarely do this) and it worked fine.
I went to the office and the laptop no longer works properly, there is no BIOS screen etc. it either goes to a blackscreen with nothing, sometimes a blackscreen with the Window login sound in the back, or just the lights on the keyboard (don't get the normal wooosh sound when I turn it on).
I've tried it on an external monitor and no difference, I can't seem to get into the BIOS either as just the black screen.
Any ideas? I'm guessing it's dead :(
If so I'm looking for a new gaming laptop, just had a look and they seem to have gone up in price a fair bit. This was a good laptop for the money back in 2022 and played what I wanted with no issues but I would like a better screen on my next one if I need to buy one...
Try - press power button for 45 to 60 sec and see if it kicks back into life.
Try using the Microsoft shortcut key combination: Windows logo key + Ctrl + Shift + B.
Cheers, have already tried those but no luck. I'm draining the battery now and will try to get a windows usb boot drive to try
Forgot to update this, I had no luck getting it work.
I did manage to get into the BIOS using my TV via HDMI, I reset that. I also managed to do a reset of the laptop via the Asus util but still unable to get a display on the laptop and at the point it would boot into windows I loose the display on the TV (via HDMI).
I guess it's new laptop time :(
