NVIDIA RTX 50 SERIES - Technical/General Discussion
I’ve got as 3080, it’s the most powerful gpu I’ve ever owned and been great. I was preparing to sell it and potentially get a 5090 for around £1200 with the 3080 offsetting some of it but £2k is wow.
I think I’ll “try” and get a 5080fe.. should still see a big jump in performance over my 3080 right?
5070ti seems the sweet spot maybe (for me at least). Probably around 4090 performance in raster, and has the same 16gb as the 580, for £729. Only 285w tdp as well.
I only have a 1440p monitor, with no interest to upgrade to 4k anytime soon so a 5070ti would probably already be overkill.
I don't think it will be near 4090 performance,more like 4080 Super,but I'm definitely getting it day one if ican
You thought the 5090 would be cheaper than the 4090?
For the 3090 and 4090 launches, I had a PSU that was right on the minimum requirement and had to go for the most bog-standard card I could get. This time around, I've got a 1.2kw PSU, which should give a chunk of headroom. Worth going for something a bit fancier with the 5090?
Most definitely
I'd saved for a 5090 but I think the usual smoke and mirrors slides on performance have brought me back to reality a little now, I really need to see raw performance numbers before I make a decision. One of the lower offerings might be more tempting if they perform well, they should all be a good bump up from a 2080ti.
We had the same plan! The jump from 3080 to 5080 looks pretty substantial, even from the 3080 to 4090 was a big leap but this may be bigger
The pricing is an issue but im hoping to recoup a decent enough chunk from selling my old PC/parts
