The chip spec for the 5080 is basically a 5090 cut in half. What that also means is that previous 3 generations the 4070, 3070, 2070 were the cards that were basically their 90s cut in half and the 80 series sat between them. So really the 5080 is still missing if you look at it this way and all the other cards got a price increase still compared if you tweak accordingly then.I have not read up all the specs yet. Is the gap between these cards greater than the 4080 - 4090? That was quite a significant difference which based on the launch pricing actually made the 4080 poor value.
5080 = 5070Ti
5070Ti = 5070
5070 = 5060
That kinda also solidifies the Vram if you take into account the 12GB would be 5060 and the two 5070's then 16GB. And would leave the space for the true 5080 (will be 5080Ti or whatever) at the £1500 ish mark and the 24GB Vram you would want tbh.
