- 7 Aug 2004
So is anyone actually buying these new cards? What games do you play day in day out that you can’t run at all or barely run ?
more and morepeople own 4k monitors these days with higher refresh rates, so thats probably the reason why people are looking to upgradeSo is anyone actually buying these new cards? What games do you play day in day out that you can’t run at all or barely run ?
I want to play Alan Wake 2 abandoned it on 4090.
Will play Indiana Jones
otherwise the aim is to hit 480hz in many games if MFG helps and native is 240hz+ I think it'll be lovely.
Will overclockers be stocking the AORUS GeForce RTX 5090 MASTER ICE 32G @Gibbo its nice to see a white card available at the start of a launch this time round![]()
You saying it didnt run on a 4090? I’m running Indy at 4k all high settings 60 fps on 6800XT, plenty smooth and looks good, a mild improvement in graphics (one that you can’t really tell when playing), wont make the game any better…….. you dont need 480hrz either.
Again essential vs ‘nice to have’ but in your case, 480hrz is overkill, if you want overkill, ok, just doesnt seem essential, unless you have unlimited money, in which case thats fine.
I think If I'm hitting 200fps natively then MFG will feel great. And if I'm lucky a bunch of games will hit 480hz natively or be engine capped. I upgrade every generation as I want more RT performance mainly. While the 4090 is very fast, it's not fast enough for games that are starting to use path tracing as I want at least 120fps maxed out at 4K with path tracing, the 4090 even with frame generation and DLSS on quality doesn't come close to reaching that. Multi frame generation should pretty much solve that.So is anyone actually buying these new cards? What games do you play day in day out that you can’t run at all or barely run ?
So your playing these games primarily because they have RT and PT?I upgrade every generation as I want more RT performance mainly. While the 4090 is very fast, it's not fast enough for games that are starting to use path tracing as I want at least 120fps maxed out at 4K with path tracing, the 4090 even with frame generation and DLSS on quality doesn't come close to reaching that. Multi frame generation should pretty much solve that.
Marilyn
Alan Wake 2 (haven't finished the two DLC's) and Indiana Jones are the main two I'm looking forward to seeing what the 5090 can do.
Totally agreeFor everyone getting too excited and hyped up about these new cards. On the plus side, the size of the cards is great, finally normal sized GPUs.
Just keep in mind that Nvidia are doing the typical nonsense of not talking about raw performance and using framegen to cover up true performance.
This should be common sense, but Jensen's claim of a 5070 getting close to a 4090 is a load of nonsense. Plus it's still half the VRAM.
Most likely he probably meant with DLSS4 multi-frame gen fake frames a 5070 can get close to a regular 4090 without DLSS.
And a video of DLSS4 was taken down, which showed a lot of artifcating and issues on those generated fake frames.
AI is still AI quality, not a replacement for real things, just a terrible imitation.
The low VRAM is still a let down. AMD could potentially have an opportunity depending on how they price their 9070XT.
Given the 5070's price, a 9070XT shouldn't be more than £450 or even £400.
But first they need to just turn up to the damn race for a start.
My bet, it's probably not worth going for one of these Nvidia GPUs at release.
If they have potential Supers on the horizon, with more VRAM, they could be worthwhile.
Otherwise, I'll hold my judgement till I see genuine benchmarks in reviews.
Long story short: wait for impartial reviews for the actual performance numbers.
Given the decent pricing, my bet is that the actual true performance increase is closer to 20% for each tier.
No, I play them because I like them, they just happen to have RT and I want a much higher frame rate than what the 4090 can provide, and I'm not reducing settings to achieve it. With GTA 6 out one day, I'd bet on that having DLSS and frame gen by then as well. 6090 will probably be out by the time PC players get to play it thoughSo your playing these games primarily because they have RT and PT?
DLSS 4 On cyberpunk 5080 first look
