- 12 May 2011
Hi all,
Apologies for the slightly rambly post but as the title suggests, I've currently got two systems I'm thinking of/looking at upgrading, they are as follows:
Media pc:
i5 6600k
CM212 cooler
Asus Z270m-prime plus
16gb gskill 3600 cl15 (running at 1066 cl19 aha!)
Msi gaming gtx 1080
Corsair TX650
Fractal Define
Personal PC:
i9 9900k
Thermaltake Frio cooler
Gigabyte B365M H
32gb Crucial 2666 cl19 mem
Palit GeForce RTX 3060 StormX 12GB
Seasonic Prime 1300W Platinum
Lamtron FC2 fan controller
Fractal Arc Midi
Both are connection to a 4k screen (TV/monitor), and play a mixture of games, heaviest of which have been Witcher 3, Hogwarts legacy, BG3, Anno 1800, Jedi Survivor. Mostly have been fine just changing settings as and when needed, but the media pc particularly has struggled more so with some titles even lowering settings, cpu hitting 100% usage etc, and my personal pc is msotly ok but I've been playing games a bit more recently and wouldn't mind a bit of a bump as well as being able to play some newer titles (Ghost of Tsushima, Star Wars Outlaws...), and so I figured I could try to upgrade both at the same time possibly utilising some of the stuff from my personal pc passed down to the media etc.
Current ideas being:
Media PC:
Sell cpu/board/gpu.
Sell i9 9900k from the personal pc, buy a cheap i5 9600 or similar and move the cpu/board to the media pc.
Buy a slightly beefier gpu (3070 type level?)
Possibly replace fans/cooler to try and help noise levels but keep the case as it's quite understated design wise and lets us use the BR drive.
Personal PC:
Sell the case/mem/gpu.
New AM5 based setup (either 7500f if going cheaper or maybe 9600x which seems to be similar price to 7600x 2nd hand)
Matx board -
32gb DDR5
3080/6800xt type GPU
New case (matx maybe something that looks ok and I'll take the computer out from under the desk to actually be visiable?) Had originally thought the Lan 207 from reading good reviews but don't think my PSU would fit and seems silly to get rid of such a high quality unit.
New cpu cooler (240/360 aio for a quiter setup if I'm considering having it on the desk but they seem to vary hugely in price?)
Mostly been looking at the 2nd hand market certainly for the GPUs to get the most value, but reckon £8-900ish overall should give a decent bump to both setups?
Open to thoughts/suggestions as I've not been keeping up with pc stuff for quite a while now since stopping overclocking 5 or so years ago.
Cheers
Media pc:
i5 6600k
CM212 cooler
Msi gaming gtx 1080
Corsair TX650
Fractal Define
Personal PC:
i9 9900k
Gigabyte B365M H
Fractal Arc Midi
Media PC:
Sell cpu/board/gpu.
Personal PC:
Matx board -
32gb DDR5
Cheers
