This could be the prototype to the 5090 looking at PCB.
MFG could be a big deal for those of us with 360hz plus monitors, also interested in testing a pulsar monitor later in the year to see if that takes things even further for motion clarity. Decided I'll get a 5080 and a 5090 as I may not need the 5090 if MFG works well from a good base native frame rate. So using both on the same display from separate PC's will be a fun little test.
Going to be interesting to see how many of the supported games I can get to 480hz and if I notice issues or not.
How are 4090 owners expecting to sell second hand 4090's at anywhere near a grand?. The 5080 is clearly a better purchase even with less vram due to new compression tech. And you're getting a brand new card!!! I predict 4090's will be worth a lot less on the used market in a few weeks especially as a lot of people will be fooled by Nvidia's dodgy marketing re the 5070 which will affect the 4090 value even more. Kind of done 4090 owners a dirty really.
I'm expecting to sell my 3090 for fifty quid.
I wounder if the thermal grizzly vireview will fit in the power connection as they look like most cards it's resesed, and the cablemod 90 degree connecter.
You are writing a lot of drivel.How are 4090 owners expecting to sell second hand 4090's at anywhere near a grand?. The 5080 is clearly a better purchase even with less vram due to new compression tech. And you're getting a brand new card!!! I predict 4090's will be worth a lot less on the used market in a few weeks especially as a lot of people will be fooled by Nvidia's dodgy marketing re the 5070 which will affect the 4090 value even more. Kind of done 4090 owners a dirty really.
We'll seeYou are writing a lot of drivel.![]()
Even if that's true (which I don't think it will be once cards are properly tested, but we'll soon find out - I predict it will match or be slightly faster than 4090), what do you think people are going to be willing to pay for a second hand 4090 when they can get a brand new 5080 for £1k...or even a 5070 with MFG for less than £600 that Jensen promised the gullible peeps matched 4090 performance???The 5080 will be slower than the 4090 in raw performance and with less VRAM. I predict a lot of people will be looking at a used 4090 over a new 5080.
I would assume the new drivers have not been supplied yet which is common practice until reveal timeI see the first 3d mark scores supposedly leaked out on chiphell forums
3D Mark Timespy Extreme: Leak shows the RTX5090 scores 22% higher than RTX4090.
That is probably one of, if not the lowest generational uplift in Timespy ever recorded for a new Nvidia flagship card
Here is some other 3D Timespy uplifts between generations
1080ti to 2080ti: 34% uplift
2080ti to 3090: 48% uplift
3090 to 4090: 73% uplift
4090 to 5090: 22% uplift![]()
1080ti 16nmI see the first 3d mark scores supposedly leaked out on chiphell forums
That's wild if true. Not sure I'll bother if that's the case.3D Mark Timespy Extreme: Leak shows the RTX5090 scores 22% higher than RTX4090.
I suppose £1400 is still a bit high considering in a few weeks you'll be able to get a new card that performs about the same in raster, supports new features, and has a new warranty for £1000. And the less VRAM on 5080 may turn out to not be as much a concern it looks (although I wouldn't bet any horses on that). That, and I suppose most 4090 owners are looking to upgrade to 5090.
4090 is still an exceptional card, and that won't change after Jan 30. It may not be enabled for the new-fangled features to play with, or push the envelope as far in AI, but does that really matter playing in game?
That said, I wouldn't pay more than £1200 for one at this point all things considered.
convince someone on fb market place that a 4090 is worth a 5070 before the benchmarks are out.5080 - 10,752 cores
4090 - 16,384 cores
Even with a generational bump in performance per core there is no chance the 5080 performs about the same as a 4090. Add to that the 4090 has more vram, with higher bandwidth. A second hand 4090 with warranty still remaining will be a better purchase than a 5080 if they're equally priced.
Sounds like you're being fooled by Nvidia's dodgy marketing lol
Depends on your setup too and if you're planning on using MFG or not. If the 5090 can get 240FPS, and the 5080 can get 200FPS, but you're using a 120hz screen, they're essentially the same cardYeah I might go with a 5080 if true. Even if a 5080 is on the lower side say 10% less than a 4090, +30% on a 5090 for an extra grand..
How are 4090 owners expecting to sell second hand 4090's at anywhere near a grand?![]()
know it's a bit tongue in cheek but they will still make great pro cards for rendering, game dev etc
Depends on your setup too and if you're planning on using MFG or not. If the 5090 can get 240FPS, and the 5080 can get 200FPS, but you're using a 120hz screen, they're essentially the same card![]()
