- 10 Sep 2006
- UK
I had an E2160 back in the day which I ran at either 3.4 or 3.6, so around a 100% overclock.
My first CPU was a Q6600 and I had it a 3200Ghz stable, never a a CPU overclock like that since
Haha the i9 920 rated at 2.6ghz would easily do 4ghz+ but you'd need to to leave a window open and a desktop fan turned towards it to blow the hot air out out lol. Stability was never a problem but heat was, all the chips from the 920 to the 980 were from the same silicon the only difference was the binning which just meant how efficient they were
Man nostalgia is strong after reading this thread.
what?...past
hahaha what a bellPassed past
+50% wasn't uncommon for a while if you bought the right cpu, but you had to do a bit of research making sure you got a mobo that could overclock, the right ram etc. My 300A did 472.5, I also had:showing age perhaps but I recall (at uni, a lab full of) celeron 300A at 300mhz, clocked to 450. +50% is probably some sort of record?
Later but I had a barton core 2600XP+ (1.83 ghz) at 2.5 (so 3400ish) under phase change.
2600K @ 4.3ghz from release till Ryzen 2xxx.
But yeah, I think "of all time". That celeron has to be close to the goat.
Edit: Doh, missed the 300A being mentioned in the OP![]()
Almost 1.6v !!!
