- 29 Sep 2010
I don't really care about power consumption, my Taichi XTX pulls 400w+ at full load and I couldn't care less as the actual cost per year for me is minimal with my usage
Cant wait to see the jump from my 2080ti!!I think you might be the 200th 40 series owner that has saidThe jump for us 30 series owners is 100-120%.
In recent years that's correct albeit I did upgrade from the 1080ti to the 3080 on launch day.it was only the 40 series that had the big jump. 10-20 20-30 didn't.
1080ti 16nmIn recent years that's correct albeit I did upgrade from the 1080ti to the 3080 on launch day.
I couldn't care less about the cost also it's more I don't want my house to burn down from 1 silly connector consuming over 1/2 KW and not to mention the size of the GPUs are getting obnoxious as well and need bolting to your case with with Frankenstein brackets haha.I don't really care about power consumption, my Taichi XTX pulls 400w+ at full load and I couldn't care less as the actual cost per year for me is minimal with my usage
There is still room for leaps, The smaller the node gets the more transistor space available to previous nodes after 3nm maybe 2 if possible if they can hit reliable yields or it will be new technology afterwards.1080ti 16nm
2080ti 12nm
3090 8nm
4090 5nm
5090 4nm
I think we've reached the end of big generational jumps. I Expect the 60 series to be around the same uplift from 5090 in percentage terms. So upgrading every 2/3 generation seems better.
mentioned on here2080 -> 3080 was about 60%
2080Ti -> 3090 was about 50%
mentioned on here
3D Timespy uplifts between generations
1080ti to 2080ti: 34% uplift
2080ti to 3090: 48% uplift
3090 to 4090: 73% uplift
4090 to 5090: 22% uplift
Mine are the same, which is why I went from 1080ti to 3080, and am looking for my next upgrade. If you upgraded to something like the 4090, then you sort of signed up to having a limited upgrade path i.e. 5090 or nothing.I have 0 issues upgrading every gen if the bump is worth it but for me my goal is a minimum of 50-60% bump in raw power.
of course, I was just responding to Adrian who mentioned "my goal is a minimum of 50-60% bump in raw power."I'm confused. So 48% wasn't a "big jump"?
I get that the 4090 was a beast and has kind of spoiled us and our expectations a bit but the 20-30 series was a decent jump IMO.
3090 wasn't the halo card though, the 3090ti was. I thought the 5090 wasn't out yet?mentioned on here
I'd want at least +50% if I was spending 1k and probably closer to 100% for 2k20% uplift from 40X0 to 50X0 would be seen as disappointing I believe
30% and above would be viewed amicably
35%+ and everyone will be pretty pleased and all complaints will be related to stock and scalping issues imo
You'd think GPUs coming out in 2025 could run 2020's Cyberpunk at more than 28fpsTimespy was released in 2016. Imagine using a 2016 game to benchmark modern cards.
You'd think GPUs coming out in 2025 could run 2020's Cyberpunk at more than 28fps![]()
if its not a competitive online shooter then I'm fine with the devs targetting a smooth 60fps with really good image quality. yes, I know this is 60fps on a 5090 but I come from the days of Crysis when PC gamers loved that they had titles that had options to push the hardware super hard. I have 144Hz monitors and for most games I don't care much beyond 60fps
By my math from the limited performance data we have so far you'd be looking at around +130% for a 5080 and +200% for a 5090.Cant wait to see the jump from my 2080ti!!
