NVIDIA RTX 50 SERIES - Technical/General Discussion
If nvidias fake frames really takes off it's going to come back to burn them
For example let's say you have a 4k 240hz OLED monitor, it's the best on the market right now. So all you need is 240fps. Nvidia comes out and says this 5070 or 5070ti will give you 240fps, great right, but now what is the point of the 5080 and 5090?
So where we are headed is in future Nvidia will sell us small and weak GPUs that create 100s of fake frames and no one will be buying high end GPUs anymore and they'll be kept and sold to data centers
If they reduce the latency so it feels like the native framerate, then they'll start charging for that **** monthly
So sacrifice image quality just to hit 4k?
Or are you complaining that your inflated expectations are rising more quickly than technology can actually do.
If Nvidia (or AMD) had never introduced RT, PT or made true GI possible etc., you'd have your Timespy quality looking games running at 4k 120 fps.
I think everyone knew what I meant.
You did as well.
Image quality of 4k is good. What are you on about?
Just looking at the Timespy 4K benchmark thread.
It requires roughly a 20,000 GPU score to get 120 average on both GT1 and GT2. Only the 4090 can achieve it.
This should make it obvious that high fidelity 4k gaming isn't even possible on something released ages ago at 120fps. Timespy Extreme also looks rubbish by today's standards even though it is 4k.
Welcome to the problem. 4k doesn't make something good.
5070ti will give you 60fps at perhaps 1440p once you start improving the games as new, more capable hardware, is available to run them. Like it always has happened.
I mean even the 4070 Ti today does 1440p60 easily at close to max settings (if you ignore path tracing tech demos).
When 4k first came out. 30 to 60fps was the norm.
Still today I would say 60fps is perfectly fine. Anything higher you may see a small improvement but I I would say 60fps is playable.
  • Like
Reactions: TNA
Those are under $600 though
Try more like +70% for the 3080, it even blew the 2080ti away. This was why people went nuts for it especially with an initial MSRP of £650.
Yea I have to conceed on this one, I'm just seeing how unreliable userbenchmark is, even outside of the AMD thing. I'm a bit in shock
So 17/18% faster than a 4080, meaning it'll be only about 13/14% faster than a 4080 SUPER. What a waste of time.
I just seen a DF post where its ~17% which is poor but if that's the improvement over the 4080 then the jump of just over 50% is good enough for me.
Ampere or older cards OK, Ada - nah.
So essentially half way between a 4080 and a 4090 for £600-800 less.
I don't think that's too bad.
Being £600 cheaper than a 4090 doesn’t make it a good price. It has been possible to get close to that level of price/performance since the 4080 Super launched. Or if you are only considering raster the 7900 XTX has been a smidge faster for even lower prices.
The 5080 is genuinely a great performing GPU, it’s just nothing special for the price.
Ah yeah you're right, just looked up the 4090 numbers at the same settings and yeah - so the 5080 is 18% faster than 4080 but still 22% slower than the 4090, roughly in the middle of the 4080 and 4090.
The 4090 still has more VRAM though, for what it's worth to anyone.
