Yes, but as always: it will depend on the game/settings.As per title, really. I play at 3840x1600 as far as possible.
Bidley, I'm not familiar with frametime vs wait time, and what they mean in relation to each other. Sorry! Could you expand a little, please?Depends on the game. My 5700x was bottlenecking my 3080 in CPU-limited scenarios (lots of NPCs in Cyberpunk etc). I went from 85fps to 100fps on the in-game benchmark switching to a 9800X3D. I play at 3440x1440.
I found PresentMon in hwinfo was a big help. Monitoring frametime against GPU/CPU wait time was revealing. CPU utlisation doesn't tell you the full story.
So your frametime is the time each frame is displayed for. If you compare that to your CPU and GPU wait time (or busy time), you can see which component is waiting on the other.Bidley, I'm not familiar with frametime vs wait time, and what they mean in relation to each other. Sorry! Could you expand a little, please?
This is a good way to test it!Install Afterburner and enable the overlay to display GPU and CPU usage as well as each individual CPU core. Check the utilisation while playing a game. The GPU should be maxed out. If not, is one of the CPU cores maxed out instead?
If a CPU core has high utilisation while the GPU doesn't, then it's a CPU bottleneck.
It's better to learn how to spot a bottleneck instead of just being told the answer to your question in my opinion.
Hmm, this is annoying as I was planning to get a 5080 but it seems like I would be leaving about 30% performance off the table with my 5600x? May be time to upgrade to a 5800X3DThis should help answer your question.
Is Your Older Ryzen CPU Fast Enough for the RTX 4080?
Today's mission is to work out how suitable the Ryzen 5600 is to use with a modern high-end GPU, such as the RTX 4080. Will the upgrade...www.techspot.com
Your 1% lows will be much better aswell. The 5800x3d is commanding a big price these days 5700x3d is only slightly slower.Hmm, this is annoying as I was planning to get a 5080 but it seems like I would be leaving about 30% performance off the table with my 5600x? May be time to upgrade to a 5800X3D
You weren't kidding! £300 for the 5800x3D and £200 for the 5700x3dYour 1% lows will be much better aswell. The 5800x3d is commanding a big price these days 5700x3d is only slightly slower.
