- 7 Jan 2009
Hey,
Been wanting to setup my own Media Server / HTPC for quite a while.
I already have a small system (Lenovo M720q) which i will add a 1TB HDD too (temp) will get bigger drive eventually.
Specs -
Basically what i want it to do, Is be a media Server, I have a few DVDs that are REALLY hard to get ahold of now and I'm worried that they will degrade/diskrot so going to copy them to digital format.
My question is how exactly should i go about setting this up? What OS would you recommend?
Should i just install Jellyfin and use it as a standalone pc connected to the TV, And if i do that how do i go about accessing this PC over the network to add further content (which i own on disk).
My other concern is will it have enough horsepower to play the content? The CPU has "Intel® UHD Graphics 630"
I don't plan to play Bluray or 4K content on this, Purely DVD content. Which i assume the TV upscales by itself.
Cheers
Specs -
- Core i3 8100T (Possibly upgrading to 9600T)
- 16GB Corsair Vengance 2400Mhz DDR4
- 256GB Intel NVME Drive (For OS)
- 1TB Hard Drive (Will upgrade to larger capacity.)
Cheers
