Moved my whole Spotify to Tidal and man  having bit-perfect streaming in the app is excellent. Can see the sample rate change between tracks on the K11 R2R's display so that's good peace of mind that it's working. Most of the 24/192 tracks are incredible definition, clearly thought has been put into which masters to use and which ones to put  onto 24/96 24/192 etc.
Feels like the Arya Stealth and K11-R2R were a match made for this type of music platform, and it's £3 cheaper than Spotify which doesn't even have a lossless service yet
It sounds like Tidal has deliberately picked 192KHz for certain tracks and 96 too for their fidelity and mastering which maximises what those trackls are capable of. it's very obvious when playing the next track and it's 24/96 or 192 vs the previous track being 44.1KHz for example.
As a comparison I played
I Want you Back by Jackson 5 on Tidal, it is 24-bit 192KHz and is exceptionally well mastered.
I then
played it on Spotify and it was immediately obvious that this copy wasn't as good quality due to the compression, even though on its own without hearing the Tidal copy you'd think it sounded amazing, which it obviously is for lossy compression, but back to back with the Tidal FLAC version it's no contest.
Happy to say that this has been my most enjoyable headphone experience to date. I would never have made the switch had I not gone into Richer Sounds at the weekend to demo speakers and the guy seeing to me mentioned a online service that transfers any music platform library to any other in one click and that I should get off Spotify and onto a proper lossless service
To be honest I'd been waiting all these years for Spotify to pull their finger out of their butt and release Spotify HiFi I figured why not wait a little longer every few months...
To get bit-perfect working properly in tidal all you have to do is set the output device to your DAC instead of system default which unlocks the settings button for it where you choose Exclusive mode and disable the volume control toggle. This will then bypass the Windows audio stack and you should see the DAC's sample rate change as you skip between tracks of varying sample rates.
