- 30 Mar 2017
That's a good point. Can't quite work out which exact ones are reference. I see alphacool fit most models, but I am a bit worried about that fitting in my O11D Evo as it may be bigger than my current FE Corsair block that only just fits.I’m guessing those with a reference PCB will be the easiest to find a waterblock for. I think INNO3D showed a render of the reference PCB, so they must be using it in a few cards at least.
