NVIDIA RTX 50 SERIES - Technical/General Discussion
Raw performance is clearly not as important as it used to be. A 5080 will give an overall better experience than a 4090 once you switch on that 4x frame gen. The difference between 2x and 4x frame gen latency will be virtually nothing. A lot depends on what games a potential buyer of a used 4090 will want to play but I'm guessing they're not buying a 4090 to play counter strike.
Whereabouts do you all think the sweet spot will be in the 5000 series SKUs in terms of price/performance?
Perhaps the 5070ti given it seems to be a scaled down 5080 still with 16Gb VRAM and just slightly less cores for ~£750?
This is easy to calculate with a few minutes of looking and doing calculations.
I'm going to use TPU's aggerate data for this and Nvidia's latest benchmarks and I'm only looking at 4k performance, lower resolutions is difficult to predict based on Nvidia's released benchmarks due to CPU overhead and you'll need to wait for reviews.
4K Results from Techpowerup, this is the average frame rate over a wide range of titles tested.
RTX4090: 152fps
RTX4080: 121fps
RTX4070ti: 98fps
RTX4070: 73fps
Now we add the new performance for RTX5000 as appears in today's official Nvidia benchmarks.
RTX5090: 152fps * 30% extra = 197fps
RTX5080: 121fps * 15% extra = 139fps
RTX5070ti: 98fps * 20% extra = 117fps
RTX5070: 73fps * 20% extra = 87fps
Then we add price:
RTX5090: $1999
RTX4090: $1599
RTX5080: $999
RTX5070ti: $749
RTX5070: $549
Now we divide the average performance by the price:
RTX5090: 197fps / $1999 = 0.09 frames per Dollar
RTX4090: 152fps / $1599 = 0.09 frames per Dollar
RTX5080: 139fps/ $999 = 0.13 frames per Dollar
RTX5070ti: 117fps / $749 = 0.15 frames per Dollar
RTX5070: 87fps / $549 = 0.15 frames per Dollar
In Summary:
The RTX 5070 and 5070ti are both equally the sweet spot for price per performance, so it doesn't matter which you choose, however given the price per frame is the same, I think the 5070ti wins because it has more VRAM for free basically.
The next best for price to performance is the RTX 5080 and then the RTX 4090 and RTX 5090 have the same price to performance.
And then there’s new features for the 6000 series and it goes again cha ching
I doubt it's going to be called the RTX 6000 series, there's already a card called RTX 6000, but built on Ada. They'll probably skip to 7000 or drop the whole RTX shtick and call it something else. Maybe AIX to capitalize on the AI gold rush. The AIX 1090 will no longer have raster or real frames, and will instead hallucinate all your frames for you directly into your brain (with unskippable ad frames).
If the 5080 ends up matching or beating the 4090 slightly (in raw performance)… I wonder how much the used 4090 market will drop to.
Fun times ahead if you have that upgrade itch!
cant wait for actual proper like for like benches vs the 4090, just by looking at the 4090 numbers I can already see the 4090 will be way ahead of the 5080, its the cores that do all the hard work and the 5080 wont be ahead, I think the prices for the 4090 will stay on point until the 6090 come in to view
I'm seriously thinking about getting a second hand 4090 instead of a 5080 at this point. The 5080 sounds so unexciting. I need to upgrade but it's a tough choice. Depends on used 4090 prices but I don't think they'll be low enough for me.
well my colleague sold his Suprim 4090 for 1450 and it was only 8 months old, he provided the OG invoice for warranty purposes and it was snapped in the 30 mins, on average they go used for 1500ish, I dont think they will go lower because when the true benches gets published it will shy away from the 5090 by 10-15% max, that about sums it up in terms of price, 1500 for a 24GB 4090 or 2400 for a 32GB 5090....
The problem with everything you just mentioned and the 10 other things Nvidia introduced is that they require RTX5000 hardware to operate and games to be built for said RTX 5000 hardware.
These new features in theory sound so cool, until you find out that they don't do anything if the game you're playing wasn't built to use these features. You're paying a premium for features which will have little to no adoption.. by the time RTX6000 is launched, there might be a dozen games that use one or more of these new features
True. It was same thing happened with RTX 2000, people like me paid premium to experienced hardware ray tracing on RTX 2080 for first time.
I will do the same thing again with RTX 5080 to experienced new 4th gen ray tracing, path tracing hardware and try out cool RTX Neural Materials, RTX Neural Shaders, RTX Neural Texture Compression, RTX Neural Radiance Cache and RTX Mega Geometry. All current games with updates and new games in 2025 will enabled to use all these new RTX 50 features, I am very exciting cant wait to test it on Alan Wake 2, Cyberpunk 2077, Indiana Jones and the Great Circle, Portal RTX, Senua's Saga: Hellblade II, upcoming Half Life 2 RTX and others.
guys, ive have just checked online for info purposes and it seems no one is selling 4090s anymore or even 4080s, pretty sure the only 4090 i saw is here, one brand only for a cool 2500 quid, everyone is out of stock, even used market its so dry, i think GPUs is such a fast paced product that there will be a mass influx of 50 series cards because resellers are avoiding stocking up on 40 series cards?
Its just when the 40 series came out there were plenty of 20 series cards available, I really hope there will be enough 50 series cards to cover the markets needs!....
TNA may as well wait for the 60s :p
Just might do that. Got free RTX upgrades coming and a huge backlog of games which all perform well enough for my needs on my 4070Ti.
Might wait and go for a 6070Ti or something :p:cry:
I still have almost 2 years warranty on this card anyway. So works out perfectly :D
New Nvidia benchmarks claims:
5090 is 30% faster than 4090
5080 is 15% faster than 5080
5070 is 20% faster than 4070
Can't beat physics Jensen
Damn. I expected 30-ish percent from the 5090, but really thought the 4080 was more bottlenecked by bandwidth and GDDR7 would do more for the 5080 even though it didn't get much of a shader bump..
So fellas, if you were proposed a 4090 FE with 1-1.5 years warranty left for £1250 or wait for a 5080, which are you choosing?
If you're happy to under volt/lower power limit it gets event quieter
If I'm reading the chart right then
300w = 23db
350w = 25db
450w = 28db
600w = 33db
Personally 38db is where I set my limit, I'm happy with any parts in my PC as long as they don't go over 38db, anything under 38db is quiet enough for me
If Nvidia's numbers are right and there's no weird frequency/fan hum/QA issues, the FE is going to be so hard to get hold of.
Who wants a huge Astral, which requires a huge case, massive airflow, when you can get a 2 slot tiny FE which performs the same?
Not to mention the FE will be £500 or more cheaper than the Astral (and other AIB flagships).
I think the only purpose of the AIB cards will be if you HAVE to have one on day one, and don't want to play the F5/waiting game for FE.
I think Nvidia could kill off the AIBs if it wants to, especially if its offering superior coolers and lower prices. The AIB's contribute nothing apart from supply chain, Nvidia to date is unable or unwilling to supply enough volume globally and AIB's are left to fill the gap
The 4090 obviously has more raw powerl if you have the juice and space in your case. However, if the 5080 works out a fair bit cheaper than maybe it's a better buy. It depends what your use case is because only you know that info.
I sold my 4090 expecting to try and get a 5090 but not too impressed withe the uplift for the requured power.
I might go for the 5080 now to put me on until until the 60 series as that will be probably when GTA 6 etc will be coming out. That will at least let me try the new features out.
I think the 5090 might end up a depreciation disaster compared to the 4090 if the 60 series comes out on a new node.
5080 would be a better buy in my opinion if it will be close to msrp.
It may be slower at launch, but I expect newer, more RT heavy games to perform better on 5080 eventually.
Longer warranty as well.
