mounting my GPU differently ?
Underboss
20 Oct 2002
Oxfordshire / Bucks
I know you can move your GPU to vertically
I'm thinking of moving my GPU because getting to the socket to take out the GPU is a pain when your GPU is 3 or 4 bays wide, you can only see 1 side of it to lower the clamp that's holding the GPU in
i have a Coolermaster MasterCase H500M
what's the best solution ?
thanks
thanks
How often do you actually remove your gpu?Cheapestt best solution is to live with the slight inconvenience every few years you upgrade.
Or go all out and get a mobo with a fancy pcie removal button
there's a fancy PCI-e removal button ?
i can do one side of the lock lever, but i cant see the other side , so its not fully unlocked
Some posh boards do, or have a sliding lever on the right side of the board where the SATA ports are. They'll increase an extornate extra for this feature though ;-)
or just use a chopstick.
Several Asus boards have a "magic" pci-e latch button. My ROG Strix B650E-F has it and it's a godsend when you have a big air cooler and a whopping great heatsink on the gpu. On mine the button is on the edge of the board just above the chipset heatsink. If you look at my boards website you can see the button with some pinky/red arrows pointing to it on the right hand edge of the board. With gpu's getting ever bigger I think most boards should have it in some form now, just like they should all have USB bios flashback.
Yep, the B650E-E also has it and it's super handy.
