My new place (rental) has a level access shower but the drain is very odd. Pretty much 75% of it is obscured by the way the drain fitting is designed (nothing looks broken).
The result is it hardly drains even when the shower ‘tap’ is barely open.
I’m a bit reluctant to put a load of bleach / harsh chemicals down it as the fittings are all plastic.
Any suggestions on how to remedy this? Only thing I could think of it to get one of those flexible, fibre optic type inspections cameras to see if there’s a blockage.
At the moment the shower tray starts to fill up when I shower. Luckily there is a lip around the edge so the floor doesn’t get soaked. However, none of the gunk from showering clears down the drain properly so it always looks dirty, even if I’ve just cleaned it.
Edit - couldn’t find a generic pic online of the same fitting. Apologies for the gross pic but this illustrates the problem:
I’ve just cut my hair so little bits of hair are from that. They’re still around despite a couple of attempts to clear it up.
